zero_china
The Spartan 6 GTP for the RX Margin Analysis
I have some issues when I use the GTP of the Spartan 6 .
Here is the setup:
clock:125Mhz
connection:SATA
IC:XC6SLX25T-2Fgg484
Tools:ISE14.7
In my design , I used the RX Margin Analysis In the horizontal eye margin scan mode of the receiving end .
Now I need to shut  the  data sampler PLL of the CDR down ,but I don't know how to shut it down ,
there are two singals that I don't understand,they are  PMA_CDR_SCAN and PMA_RX_CFG,I don't know how to set them to shut down the PLL of the CDR.
Wait for your help
Thanks in advance
venkata
What do you mean by shut the data sampler of the CDR down? do you want to fix the sampling point location?
In that case revert back the PMA_RX_CFG to the default setting and update PMA_CDR_SCAN [7:0] bits to the value to be fixed.
smarell
Community Manager
Community Manager
Please refer to RX Margin Analysis from http://www.xilinx.com/support/documentation/user_guides/ug386.pdf
zero_china
Er,What I want to shut the data sampler of the CDR down mean that I want to keep a fixed delay from starting to receive data to the CDR out , In other words ,i want to know the phase relationship between the local clock and the CDR ,and i had setted the PAM_RX_CFG as the user guide .I had tested and verified much,but,ican't have a expectant consequence.
Are there any other mechanism  for the phase of the CDR? I have no ideas!
borisq
hi,
PMA_RX_CFG[10:0] should be tied to all zeros during eye scan.
sweep PMA_CDR_SCAN[6:0] from 0x00 to 0x7F to vary the CDR phase to find out the link margin.
Boris
zero_china
@venkata
What do you mean by the default setting of the PMA_RX_CFG?  I can't find a default setting of the PMA_RX_CFG in the user guide.
venkata
I meant the value generated by GT wizard. You would have changed it for eye scan operation (PMA_RX_CFG[10:0] should be tied to all zeros during eye scan.)
