08-16-2020 06:25 AM
I am using zedboard sdk 2018.3 how to send data from pc to zedboard through ethernet and zedboard to pc through ethernet using wireshark
08-16-2020 08:13 AM
Hi @esakki ,
Use Ethernet IP based SDK example application which will do the data transfers.
Praveen
08-16-2020 10:47 PM
08-25-2020 11:05 PM
i am confused to chose the example in sdk i prefer lwip example for ethernet. kindly guide me in this case
08-26-2020 01:07 AM
https://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
The above docu should tell you how to do stuff. This is an old version. I don't know if a new exists.
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
