Zhao
Tri-Mode Ethernet MAC MDIO read return all 0.
I am debugging Tri-Mode Ethernet MAC on ZYNQ-7000. The MDIO read just returns 0. The ready bit of Register MDIO Read Data (0x50C) is 1. I try all possible PHY addresses. What next should I try?
Tags (3)
Zhao
The axi lite state machine in the example design does not wait a time long enough for my PHY begins to function. I add a poll loop at the beginning to check the PHYID, if the PHYID is valid, then I proceed the normal MDIO configurations. Now it works.
nanz
Hi @Zhao ,
Can you please first test in simulation and see if that works? You can compare the interface between your simulation and hardware and see differences.
Also, your MDIO clock should be 2.5MHz or below. Please confirm that too.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
Zhao
Thanks for your reply. The simulation works fine. The MDC clock is below 2.5MHz. Is there anything else that I should pay attention to?
nanz
Did you add an ILA on the interface? If you could compare the MDIO interface between the simulation and HW ILA, you will get where the issue comes from.
Zhao
nanz
Hi @Zhao ,
Great to know the issue is resolved. Could you please mark your above thread as accepted solution? So it will also benefit other forum users. Thank you!
