Observer bdillahuntdra
Tri Mode Ethernet MAC v9.0.5
We purchased a license for the Tri mode ethernet MAC v9.0.5 and I am able to run a successful place-and-route using the example design.  However, I cannot find a way to modify any of the files within the core (like the one for the RGMII interface).  I need to adjust the delays of the input side IDELAYE3s since I'm currently unable to get the receive side of the RGMII interface to produce valid data.  Does anyone know how to do this?
Brian
Re: Tri Mode Ethernet MAC v9.0.5
You can modify the idelay tap setting by providing constraints in the top level xdc and no need to modify the files.
Below see below info from PG051 on the guidance to meet timing.
Another example design file, <component name>_user_phytiming.xdc, is also
provided to show how to override default XDC settings provided by the core for setup and
hold checks on the selected physical interface.
This is useful in case the interface timing constraints cannot be met. The constraints can be
relaxed by adjusting the values in this XDC file which is set to be processed after all other
XDC files. This also allows the IODELAY tap delay setting to be adjusted without needing to
modify the XDC files provided with the core.
Satish
Satish
Satish,
Thank you for the response.  I really need to modify the files within the Tri-mode ethernet mac core in order to have code that will be used to automatically adjust the shift values of the IDELAYs based on whether or not valid data is being received from the RGMII interface.  I also need to add in ILAs and VIOs to debug the core in order to find out why I'm not seeing data coming from the PHY on the RGMII interface.
Is there any way to do this?  I tried adding the core's supporting files by hand (as opposed to instantiating the .xci file in the design) but I could not get Vivado to recognize the encrypted core for the file, "tri_mode_ethernet_mac_v9_0_rfs.vhd".
Brian
Satish,
You can ignore that last message. I was finally able to get the MAC to work by modifying the attributes of the ISERDES components in the 'device' view of the implemented design.
Brian
