Tri-mode Ethernet Mac
I plan on using the Tri-mode Ethernet Mac v9.0 in my latest design. However I also had the spec for an older MAC v5.5. On page 6 of this guide, shown below, I am concerned with note 3, “For Virtex-7, Kintex-7 and Artix-7 devices, it is I/O dependant with HR I/O supporting MII/GMII at 3.3V or lower and RGMII at 2.5V or lower and HP I/O only supporting 1.8V or lower ”. The Tri-mode Ethernet Mac v9.0 guide does not have this note. I am using a Kintex-7, HR I/O at 3.3V and I wanted to used RGMII. Is this possible with the latest Ethernet Mac core v9.0?
LogiCORE IP Facts Table
Core Specifics
Supported
Device Family(1)
Zynq™-7000(2), Virtex®-7, Kintex™-7, Artix™-7,
Virtex-6, Spartan-6(3)
Supported User
Interfaces
AXI4-Lite, AXI4-Stream
Resources See Table 2-2 to Table 2-4.
Provided with Core
Design Files
ISE®: NGC netlist
Vivado™: Encrypted RTL
Example Design VHDL and Verilog
Test Bench Demonstration Test Bench
Constraints File
ISE: UCF
Vivado: XDC
Simulation
Model
Verilog and/or VHDL Behavioral Model
Supported S/W
Driver
N/A
Tested Design Flows(4)
Design Entry
ISE Design Suite 14.4
Vivado Design Suite 2012.4(5)
Simulation
Mentor Graphics ModelSim
Cadence Incisive Enterprise Simulator (IES)
Synopsys VCS and VCS MX
Synthesis
Xilinx Synthesis Technology (XST)
Vivado Synthesis
Support
  1. For a complete listing of supported devices, see the release
notes for this core.
     2. Supported in ISE Design Suite implementations only.
     3. Virtex-6 devices support GMII and MII at 2.5V only; see
[Ref 1] for more information. For Virtex-7, Kintex-7 and
I/O only supporting 1.8V or lower.
     4. For the supported versions of the tools, see the Xilinx Design
Tools: Release Notes Guide.
     5. Supports 7 series devices only.
Re: Tri-mode Ethernet Mac
Tri-Mode Ethernet MAC v9.0 supported device families are UltraScale+, UltraScale, Zynq -7000, 7 Series.
For 7 series and Zynq-7000 families, the voltage standard used depends on the type of I/O used: HR I/O supports RGMII at 2.5V or lower and HP I/O only supports 1.8V or lower. Despite this being the defined RGMII voltage, most PHYs require 2.5V and therefore an external voltage converter is required to interoperate with any multi-standard PHY when using 7 series HP I/O.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Pratap
