Trouble getting txperf.c in XAPP1026 to compile.
I added 1026_14_3\zc702_GigE\repo to the repo in SDK, but I am still getting the following errors:
1. 'AF_INET' undeclared (first use in this function) txperf.c /tx_performance/src line 59 C/C++ Problem
2. 'SOCK_STREAM' undeclared (first use in this function) txperf.c /tx_performance/src line 59 C/C++ Problem
3. storage size of 'ipaddr' isn't known txperf.c /tx_performance/src line 49 C/C++ Problem
4. storage size of 'serv_addr' isn't known txperf.c /tx_performance/src line 51 C/C++ Problem
I changed the ip addres type from "struct ip_addr" to "ip_addr_t" (aparrently because lwip was updated since txperf.c was written) which solved error 3, but I am at a loss at what else I would need to change to fix errors 1, 2, and 4 and get the example to compile.
Re: Trouble getting txperf.c in XAPP1026 to compile.
Could a mod please move this to processor system design?
