Ultrascale+ 100G cmac simulation time too long
I am simulating the example design of the ultrascale+ 100G IP, using the vivado 2019.1.3 and modelsim tools to simulate the IP, by followed the pg203, i did define SIM_SPEED_UP in the testbench, but for now, i had done the simulation for three days, the signal of rx_done_led in the pkt_gen_mon module is still deasserted, which caused the simulation is still unfinished, but all the stat signals seemed to be normal, the stat_rx_aligned and the stat_rx_status signals were hign level now, and the transmit signals had sent the patterns, only the reveive path got nothing, is this a normal phenomenon, or just i wait for finished?
The modelsim scripts show below:
# INFO : SYS_RESET RELEASED TO CMAC IP
# INFO : WAITING FOR THE GT LOCK..........
# INFO : GT LOCKED
# Core_Version = 2.6
# INFO : WAITING FOR CMAC RX_ALIGNED..........
# INFO : RS-FEC IS ENABLED
# INFO : RX-ALIGNED
# INFO : Packet Generator and Monitor (SANITY Testing) STARTED
# Number of data packets to be transmitted = 1000, each of packet size = 522Bytes, Total bytes: PKT_NUM * (PKT_SIZE + 4[CRC]) = 526000Bytes
# INFO : ALL PACKETS SENT, NO ERRORS
The pics of modelsim scripts and wave list below:
Vivado 2019.2 fixed this issue, both modelsim and Vivado worked well
It is four days now, i am now considering that there are likely to have some bugs in the IP intergrated in Vivado 2019.1.3
Do you mean Packets are sent on TX while RX doesn't receive any?
Is this IP core example design? Have you tried Vivado Simulator?
Yes,it is the example design with the definition of SIM_SPEED_UP, and both Modelsim and Vivado Simulator had been tried.
Packets are sent on TX corectly, but RX receiver none.
Please try 2019.2
Please provide the IP core configurations
I had just updated the Vivado to 2019.2, but since the core version(v3.0) is still same with 2019.1, i don't think there will any changes.
The IP core configurations is CAUI4, 161.1328125Mhz, AXIS interface, RS-FEC enabled and AN/LT disabled.
Advisor
Advisor
Hi @guozhenp ,
I'm seeing the same issue with CMAC core revision 3.0 and Vivado 2019.2. Example design simulation doesn't progress beyond "WAITING FOR CMAC RX_ALIGNED". It run overnight and simulated 5.3ms. I tried multiple config options, including disabling RS-FEC. Also tried adding "xvlog -d SIM_SPEED_UP" option and making sure it applied.
Attached is my CMAC configuration.
Evgeni
