Unable to avoid GTXE2_COMMON primitive inference in Chipscope IBERT core
I have generated a Chipscope IBERT core for one of the GTX lane (MGT1_117) in Kintex-7 FPGA using ISE version 14.6 coregen tool. I am not interested in using GTXE2_COMMON (Quad PLL) primitive, as my lane rate is very low which is 1.25Gbps. So i have un-checked the QUAD PLL option while generating the core. But still GTXE2_COMMON primitive is getting instantiated from the corresponding GTX_QUAD_117. I confirmed the same by importing implemented design to FPGA editor.
Can anybody suggest, how do i avoid GTXE2_COMMON primitive inference in IBERT core!
Thanks in Advance!
Phani.
Community Manager
Community Manager
Re: Unable to avoid GTXE2_COMMON primitive inference in Chipscope IBERT core
Hi Phani,
It is not possible to disable the gtxe2_common from the IBERT design.
If you turn off the QPLL option in the IBERT core generation GUI then the design feeds the refclk to channels through CPLL. You can confirm this by viewing the design in FPGA editor.
Is there any specific reason why you would like to remove the common block from the design?
Krishna
Have a look at the below AR to know why a GT_common primitive is needed
http://www.xilinx.com/support/answers/43339.html
Satish
Hi Krishna,
Thanks for your response and i understand from FPGA editor that refclk is routed to the channel through CPLL only. Then why GTXE2_COMMON primitive is unnecessarily getting instantiated??
In my design, i have to enable Two channels in the same QUAD. One channel using IBERT core and the second channel using SDI core. And i wanted to integrate both the channels to have a common FPGA image. SDI core definitely requires GTXE2_COMMON in my design. Hence the implementation tool throwing an error saying that, COMMON primitives are over mapped. How do i resolve this issue?
Phani.
Community Manager
Community Manager
Hi Phani,
IBERT is designed to be a core that takes over the GT control and data path, including the COMMON block.
In this case, you need to manually edit the IBERT core wrapper to remove the common primitive.
Krishna
Hi Krishna,
Actually i have already decided to modify the IBERT wrapper file. When i look into the top level wrapper, i understood that source codes are not provided and instead ".NGC" file is provided. Then how do i play with wrapper file when it is in ngc format?
Phani.
Hi Krishna,
Do you suggest any other way to resolve this issue?
Phani.
Community Manager
Community Manager
Hi Phani,
You are correct, the IBERT core is encrypted and you can remove the wrapper from this.
Try to use the common of the IBERT core with the other core. This ar can be of some help http://www.xilinx.com/support/answers/55369.html
Krishna
Community Manager
Community Manager
Hi Phani,
IBERT is used to check the quality of the channel. Is there a specific reason why you want to include this in your main design?
Krishna
Hi Krishna,
Thanks for your suggestion. But how do i use COMMON block of IBERT with other cores. For that, i need to bring out the "QPLLOUTCLK" from IBERT to connect QPLLINCLK for my custom GTX core, right?
The reason why i wanted to have IBERT in my main design is, i don't want any FPGA interfaces left un-tested in the final FPGA image, which i am gonna release to my customer. :)
Phani.
