latest.vlsi
Updated design based on vivado
Hi ,
Following AR http://www.xilinx.com/support/answers/46384.htm has attached ISE example design.
If there any updated reference design based on vivado for kC705.
Thanks in advance.
yenigal
Yes there is updated reference design for Vivado.
Refer below link.
http://www.xilinx.com/support/answers/59968.htm
Satish
yenigal
Refer below link.
Satish
latest.vlsi
Thanks Satish for your quick reply.
