Observer almehdi
VC707 xdc
I have a problem with the xdc provided in the user guide of the vc707 I'd like to connect the MOD_DETECT and TX_FAULT of the sfp but there is no pin allocated to it, is it normal ?
Re: VC707 xdc
These signals are not mentioned in the XDC as these are not connected directly to the FPGA and these status signals can be monitored directly by the jumper points to which these are connected to.
Satish
Observer almehdi
Re: VC707 xdc
But for example if I have to connect them to the pcs/pma core do I just have to make constants that will pass this check and then if there is an error or something not working check directly on the fpga ?
Re: VC707 xdc
The 10G PCS PMA core does not take the TX fault and Mod detect signals as inputs to the core.
You need to tie these signals as indicated in PG068
Satish
Observer almehdi
Re: VC707 xdc
The pcs/pma cores take tx_fault and signal_detect ( which is a combination of Los and Mod detect signal ) that's what I unterstand of the pg068 ver.4.1 page 15 , maybe I misunterstood ?
