Observer caobin
VC709 two xgmac, one receive, one transmit; transmit mac no output
I am testing xgmac core with pcs_pma core on vc709.
MAC1 receives signal by sfp+ module, and MAC1's rx bus is connected to MAC0's transmit engine; however, it seems that MAC0 transmit engine is not working; its output signal txd on xgmii is fixed to 0x0200009c 0200009c with txc=0x11.
When I connect the MAC1's rx bus to its own mac tx bus, MAC1's tx output is working.
When I use a splitter to split some optical signal from MAC0's sfp+ transmitter into MAC0's sfp+ receiver, the MAC0's transmit engine is working, and optical signals can be transmitted through MAC1's sfp+ receiver to MAC0's sfp+ transmitter, and go back to the data analyzer.
It seems that I could not force MAC0's tx engine work when there is no light signal on its rx sfp+ module. How can I force the mac tx engine work even if there is no light signal on its rx sfp+ module?
Can anyone give me suggestions?
Best Regards,
James
Observer caobin
Re: VC709 two xgmac, one receive, one transmit; transmit mac no output
more information about this topic:
MAC configuration is not implemented. I just let the axi-lite interface afloat except the axi clock and reset signals.
You can tie the signal detect input to the 10G PCS PMA core to 1 if you are not connecting to the optical module.
Also have a look at PG068 debugging section to have more details on remote fault condition.
Satish
Observer caobin
Hi Satish,
Thanks for your suggestion.
The core will transmit the remote fault bytes 0x0200009c 0200009c when it's receiver  is in local fault state.
Configure the Fault Inhibit bit to 1 in the Reconciliation Sublayer Configuration Word register so that it tranmits the data.
Satish
Observer caobin
thanks Satish, it is exactly as what you said.
Glad to know that the design is working now.
Please close the thread by marking the post which answered as the solution,so that is will be useful for others.
Satish
