Virtex-5 Embedded Ethernet MAC TX Problem
Dear Experts
                       I am using ml507 board with fx70T device and trying to run example design of loopback. Its my first fpga development experience. I am generating the core with the configuration
                      1- GMII interface 1Gb/s fixed speed
      2- Remaining are on default no changes
                       3- Host type None.
I am using an application name ostinato to send frames to the board. Rx LED on the board blinks and I can see the sent frames on the PC side. But no frames are sent back by the Board. I would be highly thankfull for your support.
Waiting for your reply.
Re: Virtex-5 Embedded Ethernet MAC TX Problem
I have sorted out that there is a problem with the UCF. I have edited it by seeing diffrent posts but has been unable to sort out the issue. Plz help!
You are more likely to get help if you post the UCF, noting where you think the problem area might be...
"If it don't work in simulation, it won't work on the board."
Dear
                           Here is the ucf file and after a lt of modification and I beleive it is ok nw. But the problem still presist. Please help.
