DKNEWS
[Vivado 12-4739] Multiple critical warnings for GMII to RGMII : set_false_path:No valid object(s) found for '-rise_to [get_clocks -of_objects [get_ports RGMII_0_rxc]
I'm using GMII to RGMII IP and getting critical warnings when compiling.. can't find any answers why. XDC file is generated automatically.
Example:
[Vivado 12-4739] set_false_path:No valid object(s) found for '-fall_to [get_clocks -of_objects [get_ports RGMII_2_rxc]]
I'm attaching constrains file generated by the tool, exported list of warnings and part of the block diagram
Thank you for your help and stay safe
Dennis
DKNEWS
fixed issue myself. Problem is that clocks RGMII rx clocks from PHY should be explicitly defined in the user constraints file that is marked PROCESSING_ORDER:EARLY
Adding these lines to myconstraints_early.xdc file fixed the issue:
# RGMII recovered clock from PHY
create_clock -add -name rgmii_rxc0 -period 8.000 [get_ports RGMII_0_rxc]
create_clock -add -name rgmii_rxc2 -period 8.000 [get_ports RGMII_2_rxc]
DKNEWS
