aishwaryaakul@
WEB SERVER ON ZEDBOARD
Hello sir/madam,
i want  to run web server on zedboard.
i have  referred xapp1026 tutorial and files.but  i have no idea how to run webserver on zedboard.
can you please suggest tutorial for block design and sdk code for webserver.
please reply as soon as possible.
Thanks&Regards
Aishwarya Akul
stephenm
xapp1026 has a webserver demo. What is the issue with this?
aishwaryaakul@
hello,
when i add these (xapp 1026) files into sdk i get error.
can you plz  guide step by step process of vivado and sdk for web server.
Thank you..
dpaul24
aishwaryaakul@ ,
This document does give you step by step guide.
If you cannot achieve something please be specific about your problem. Consider yourself lucky that such a docu exists and you do not have to build your design from scratch.
Please re-write this post to include -
1. what you have done,
2. what is the error,
3. supported by screenshots and/or actual code snippets where the problem is likely to be!
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
aishwaryaakul@
Hello sir,
thanks for reply
project steps:- zedboard
1)created block design on vivado including gpio(led,switches),zynq7 processing system,enable uart and ethernet on ps section.
2)this wrapper file exported to sdk .
3) import raw_app project from xapp 1026  tutorial.after building of this project error msg comes.
Aishwarya
