andrea@ross
Wake on lan using PL eth subsystem
Following this wiki (https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842232/Zynq+UltraScale+MPSoC+Power+Management+-+Linux+Kernel#ZynqUltraScale%EF%BC%8BMPSoCPowerManagement-LinuxKernel-WakeonLAN) I've enabled the PM in petalinux 2019.2, I can suspend correctly the system but then I can't wake it up from the 10G/25G ethernet subsystem.
In the wiki they use these commands to suspend and select the wakeup source:
$ echo enabled > /sys/devices/platform/amba/ff0e0000.ethernet/net/eth0/power/wakeup
/ Suspend
$ echo mem > /sys/power/state
In my case I tried with /sys/devices/platform/amba_pl@0/a0042000.ethernet/net/eth0/power/ but I can't find the wakeup file.
I have only these files:
  • autosuspend_delay_ms
  • control
  • runtime_active_time
  • runtime_status
  • runtime_suspended_tim
How can I "wake on lan" from the 10G/25G subsystem?
Best regards,
shabbirk
Hi andrea@ross
As can be seen from the AXI ethernet driver wiki, we don't have wake on LAN support
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842485/Linux+AXI+Ethernet+driver
We have this support however in PS GEM driver:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841740/Macb+Driver
Shabbir
andrea@ross
Hi @shabbirk,
there is a way to wake the system from the PL?
shabbirk
Hi andrea@ross
Wake on LAN is actually part of suspend/resume of the driver which in this case is not implemented
Shabbir
