What is the fastest way to get networking working on Zedboard?
I would like to add netwroking capability, specifically, sockets, to my Zedboard.
I don't want to install Linux.
I found an old Appnote, xapp1026.pdf based on the Vivado from 2014.
Is there a more recent application note or some tutorial that shows step-by-step how to add an IP (for instance, lwip) on the latest Vivado to a system on chip based on the Zedboard?
Re: What is the fastest way to get networking working on Zedboard?
@dag1,
Read the latest version of the PG051, TEMAC documentation and follow its example_design. This would be some work only with the PL section.
Fop a Zynq based xapp - https://www.xilinx.com/support/...notes/xapp1305-ps-pl-based-ethernet-solution.pdf
FPGA enthusiast!
All PMs will be ignored
The example_design has XDC for Kintex 705 and Artix AC701.
I have Zedboard (Xilinx Zynq-7000).
It would be too complex as a student project to implement this.
I am looking for something easier. A step-by-step tutorial suitable for student project. How to build Vivado project for Zedboard that has Internet Protocol (IP).
@dag1,
Then I guess time is on your side. :-) The fastest way is not the best way to learn (for a student)!
Google more for your specific needs. Also the IP is a protocol implementation that is mostly done at a higher level through software implementation.
Look for the Ethernet chapter from Adam Taylors tutorials: http://zedboard.org/content/microzed-chronicles
You also have the Avnet Zedboard forums for more specifics.
FPGA enthusiast!
