Teacher rcingham
Where are TEMAC blocks in FX100T?
Virtex-5 FX100T
ISE 12.3
I am trying to find out where the TEMAC blocks are in the FX100T device, so that I can pick the closest to the MGT that our board is already using to connect to the SFP. By using FPGA Editor I have discovered where the PowerPC and PCIe Endpoints are, but not the TEMACs.
Or are there only soft MACs, in which case I will probably look a bit of a Charlie for asking...
Thanks in anticipation.
"If it don't work in simulation, it won't work on the board."
Professor
Professor
Re: Where are TEMAC blocks in FX100T?
That part should have two TEMAC duals.  They appear as rather small boxes in the FPGA editor
compared to other hard components.  You can search for them using Edit --> Find... and look
for TEMAC_X0Y0 like:
-- Gabor
Professor
Professor
-- Gabor
Teacher rcingham
Thanks, I wasn't looking for 'Site's...
Actually, it seems to be a bit easier to blunder across them in PlanAhead, which is what I have just done.
And now I know that the SFP isn't connected to either MGT that has a TEMAC next to it. However, as it connected to one of the adjacent MGTs, there is a fair chance of getting it to work without a board re-spin, which is nice.
Newbie hzc191025
thank you! I got it!
