yang.liu@avnet.com
Where to get PTP offload on R5 in zynqmp
I found PTP offload at wiki -- "Xilinx TSN Solution".  But where to apply for the R5 source code for TSN application?
"Xilinx TSN solution offers running multiple instances of 802.1AS PTP function(ptp4l) on RPU of zyng Ultrascale platform. This is implemented by porting PTP(ptp4l) daemon and part of TSN IP driver to FreeRTOS running on R5. The control path is handled through A53(main processor), through OpenAMP frame-work."
Tags (3)
nanz
Hi yang.liu@avnet.com ,
It seems you have opened a support case on it. That is probably the best way to have the info.
Could you please make sure this forum thread is also up to date once you get an answer? Thank you.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
nanz
yang.liu@avnet.com
Hi Nanz,
As it's not offically released, if anyone wants to get it, the only way is to ask for local Xilinx support.
But it's quite a lot of test need to do.
