Dennis
X2522-25G-PLUS specs question
I have couple of questions regarding X2522-25G-PLUS:
Does this adaptor supports multi-mode?
I have two lines to connect to the adaptor. One is 1G and second is 10G. Will connecting different speeds to each port work properly? ( I"ll use 1G transceiver in one of the ports)
abrunnin
The answer to both of these questions is "yes".
If an SFP that supports multiple speeds is attached, then the switch will get to decide which is used.  (Typically, it will select the highest rate.)
And each port of the card can individually use a different speed.  (On this card - 1G, 10G and 25G are supported).
abrunnin
HI Dennis.
Yes, this is supported.  Each physical port can be independently configured to 1G, 10G, or 25G.
abrunnin
