Observer tomo_naga
XAPP1305: petalinux 2017.4 build error
Hi.
I'm trying to implement the XAPP1305 design to ZCU102 (rev. 1.1) in the 2017.4 environment (Vivado and Petalinux).
Firstly, the design implemented by Vivado 2017.1 was updated, namely IP upgrade, by Vivado 2017.4.
Secondly, the petalinux project using .hdf by Vivado 2017.4 was created.
And then, I got the below errors at the petalinux building step.
ERROR: device-tree-generation-xilinx+gitAUTOINC+3c7407f6f8-r0 do_compile: Function failed: do_compile (log file is located at /opt/petalinux/xilinx-zcu102-zu9-es2-rev1.0-2017.4/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/log.do_compile.11456)
ERROR: Logfile of failure stored in: /opt/petalinux/xilinx-zcu102-zu9-es2-rev1.0-2017.4/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/log.do_compile.11456
Log data follows:
| DEBUG: Executing shell function do_compile
| /opt/petalinux/xilinx-zcu102-zu9-es2-rev1.0-2017.4/build/../components/plnx_workspace/device-tree/device-tree-generation/plnx_aarch64-system.dtb: ERROR (phandle_references): Reference to non-existent node or label "rx_data_fifo_0"
| ERROR: Input tree has errors, aborting (use -f to force output)
| WARNING: exit code 2 from a shell command.
| ERROR: Function failed: do_compile (log file is located at /opt/petalinux/xilinx-zcu102-zu9-es2-rev1.0-2017.4/build/tmp/work/plnx_aarch64-xilinx-linux/device-tree-generation/xilinx+gitAUTOINC+3c7407f6f8-r0/temp/log.do_compile.11456)
ERROR: Task (/opt/petalinux/components/yocto/source/aarch64/layers/meta-xilinx-tools/recipes-bsp/device-tree/device-tree-generation_git.bb:do_compile) failed with exit code '1'
Based on the above errors, I deleted the code
axistream-connected = <&rx_data_fifo_0>;
axistream-control-connected = <&rx_data_fifo_0>;
 on "pl.dts" in  "/opt/petalinux/xilinx-zcu102-zu9-es2-rev1.0-2017.4/components/plnx_workspace/device-tree/device-tree-generation".
After that, the re-build could be completed without errors and the linux could be booted on ZCU102.
However, I got the below kernel panic when starting up eth1(10GE).
root@xilinx-zcu102-zu9-es2-rev1_0-2017:~# ifconfig eth1 up
[   27.107103] xilinx_axienet 80010000.ethernet eth1: __axienet_device_reset: DMA reset timeout!
[   27.117112] xilinx_axienet 80010000.ethernet eth1: __axienet_device_reset: DMA reset timeout!
[   27.125864] Unhandled fault: synchronous external abort (0x96000210) at 0xffffff8008f2040c
[   27.134128] Internal error: : 96000210 [#1] SMP
[   27.138611] Modules linked in: uio_pdrv_genirq
[   27.145000] CPU: 2 PID: 2293 Comm: ifconfig Not tainted 4.9.0-xilinx-v2017.4 #1
[   27.154313] Hardware name: ZynqMP ZCU102 Rev1.0 (DT)
[   27.161312] task: ffffffc8794d8380 task.stack: ffffffc87ad7c000
[   27.169320] PC is at axienet_device_reset+0x55c/0x6e8
[   27.176431] LR is at axienet_device_reset+0x53c/0x6e8
continued...
I've already confirmed that the XAPP1305 design implemented in "the 2017.1 environment" worked.
I'd like to build the design in the 2047.4 environment.
Does anyone have any solutions or comments?
Thank you very much in advance.
Re: XAPP1305: petalinux 2017.4 build error
Hi @tomo_naga,
You will also need to connect txoutclksel/rxoutclksel to 101 in the toplevel BD file. The IP has been updated in the newer version of the tool to bring out the clock select signals for customer use. You should not see the "DMA reset timeout" error with this change.
Hi @tomo_naga,
When upgrading xapp1305 to 2017.3/4, there is a patch needed. Please check the details in the following wiki page:
https://forums.xilinx.com/t5/Networking-and-Connectivity/Zynq-AXI-Ehernet-Subsystem-with-MII2RMII-problem/td-p/849418
Observer tomo_naga
Thank you very much for your reply!
I tried to build the project with the patch file you uploaded.
Although the build could be done without any errors, the same kernel panic occurred when eth1 was started up.
Do you have any ideas?
Thank you in advance.
Hi @tomo_naga,
Observer tomo_naga
Thank you for your kind reply @nanz!
The design after reflected your suggestions worked done well!
