rathnakar
XAPP1305
Im trying to implement PS-PL based  EMIO ethernet using the tcl file provided in XAPP1305. When the project is sourced through tcl file,  "1G/2.5G Ethernet PCS/PMA or SGMII core" is created in block diagram. This PCS/PMS core has a pin by name "an_adv_config_vec[15:0]". The tcl file tries to set the value of this vector to "100001", which falls out of the range in 16 bit representation. Due to this error project creation is halted. Can someone help to solve this problem?
Thanks in advance.
rathnakar
Hi @ nanz. No, I didn't.
I got the problem solved by putting the value of an_adv_config_vec[15:0] as 0x9801, as per the PCS/PMA core userguide.
Thanks for the reply.
nanz
Hi @rathnakar ,
Did you download the design from here:
https://github.com/Xilinx-Wiki-Projects/ZCU102-Ethernet
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
rathnakar
