Xilinx ZynqMP jumbo frame not working
Dear support,
We've been trying to bring up Jumbo frame support on a Trenz board running Zynq MPSoC (4CG-1E) . But got the following error when running ifconfig eth0 mtu 9000:
root@petalinux:~# ifconfig eth0 mtu 9000
SIOCSIFMTU: Device or resource busy
We can see via dmes that macb driver is configured and running as it should (according to https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841740/Macb+Driver )
[ 6.815918] pps pps0: new PPS source ptp0
[ 6.819948] macb ff0e0000.ethernet: gem-ptp-timer ptp clock registered.
[ 6.826652] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.966711] macb ff0e0000.ethernet eth0: link up (1000/Full) [ 9.972383] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
in kernel config file, all the following configured as 'Y':
CONFIG_ETHERNET
CONFIG_NET_CADENCE
CONFIG_MACB
CONFIG_NETDEVICES
CONFIG_HAS_DMA
Is there anything else that I'm missing?
Thanks for your attention,
Lichang
Re: Xilinx ZynqMP jumbo frame not working
Thanks@nanz .
Here is the gem3 in ./components/plnx_workspace/sources/linux-xlnx/arch/arm64/boot/dts/xilinx/zynqmp.dtsi
gem3: ethernet@ff0e0000 {
compatible = "cdns,zynqmp-gem", "cdns,gem";
status = "disabled";
interrupt-parent = <&gic>;
interrupts = <0 63 4>, <0 63 4>;
reg = <0x0 0xff0e0000 0x0 0x1000>;
clock-names = "pclk", "hclk", "tx_clk";
#address-cells = <1>;
#size-cells = <0>;
#stream-id-cells = <1>;
iommus = <&smmu 0x877>;
power-domains = <&zynqmp_firmware PD_ETH_3>;
And in ./project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi
/* ETH PHY */
&gem3 {
status = "okay";
compatible = "cdns,zynqmp-gem";
ethernet_phy0: ethernet-phy@0 {
compatible = "marvell,88e1510";
device_type = "ethernet-phy";
phy-mode = "rgmii-id"; /* note: no difference with and without  this line */
reg = <1>;
BTW, I'm using 2019.2 - both petalinux and Vitis.
Lichang
HI @lichangche ,
What does your DTS look like?
To enable jumbo frame, the compatible should be "cdns,zynqmp-gem".
Thanks@nanz .
#size-cells = <0>;
/* ETH PHY */
&gem3 {
status = "okay";
reg = <1>;
Lichang
FYI - Relevant kernel message during boot up is attached.
Here is some relevant section:
[ 4.348079] zynqmp_pll_disable() clock disable failed for dpll_int, ret = -13
[ 4.426176] Marvell 88E1510 ff0e0000.ethernet-ffffffff:01: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:01, irq=POLL)
[ 4.440080] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 28 (80:1f:12:37:34:b7)
It is to do with configuration steps. I've reconfigured it and jumbo frame is working.
Hi @lichangche ,
Brilliant to hear the issue is resolved. Can you please mark your relavent thread as "accepted solutions"? So it will benifit other forum users too. Thank you!
