ZCu106 PS Ethernet UDP high loss with iperf testing
Hi, I am using ZCU106, SW version 2019.2 , I am using PS Ethernet on Ultrascale+.  Its using GEM3.  I am running iperf UDP test. I found significant data loss around 64-70% when set BW 1Gbit,
I see no loss upto 300Mbit only, as soon as I start increasing BW data loss start significantly.
I am running this command :
iperf3 -c ip -p 3002 -u -b 1000m
 iperf3 -c ip -p 3002 -u -b 1000m -w 64K
I am not sure what to do next for debugging PS HW as I dont have much control on it.
I have refereed this,
https://www.xilinx.com/support/documentation/application_notes/xapp1305-ps-pl-based-ethernet-solution.pdf
Please guide me how to solve this problem.
My Test Setup is : ZCU106(client) ---> Eth Switch ---> Computer(Server).
When I tried otherway around as Zynq become server and PC become Client for UDP test
I found this error:
Server listening on 3002
Accepted connection from 192.168.0.17, port 56915
[ 5] local 192.168.0.12 port 3002 connected to 192.168.0.17 port 54041
[ 52.483611] macb ff0e0000.ethernet eth0: not whole frame pointed by descriptor
[ 52.530478] macb ff0e0000.ethernet eth0: not whole frame pointed by descriptor
[ 52.584141] macb ff0e0000.ethernet eth0: not whole frame pointed by descriptor
[ 52.591359] macb ff0e0000.ethernet eth0: not whole frame pointed by descriptor
[ 52.598584] macb ff0e0000.ethernet eth0: not whole frame pointed by descriptor
[ 52.605811] macb ff0e0000.ethernet eth0: not whole frame pointed by descriptor
[ 52.613104] macb ff0e0000.ethernet eth0: not whole frame pointed by descriptor
[ 52.620346] macb ff0e0000.ethernet eth0: not whole frame pointed by descriptor
[ 52.627565] macb ff0e0000.ethernet eth0: not whole frame pointed by descriptor
[ 52.634828] macb ff0e0000.ethernet eth0: not whole frame pointed by descriptor
I tried with this patch but doesn't make any difference:
https://www.xilinx.com/support/answers/71168.html
is there anyone has any idea?
Hi @systemsdeveloper
Can you try to transfer it or measure performance without having a switch connected? I mean Rj45 connected between board and PC. Seeing any Rx errors in ifconfig output?
Best Regards
Shabbir
@shabbirk
Thanks for reply. yes, I did direct connection means PC-->FPGA PS Ethernet, I found more worse result. I found 72% loss on iperf UDP test. Any idea How to debug further?
is there any further idea? I am sure people would prefer to use PS Ethernet instead of PL.
anyone has seen this issue with Ultrascale+ FPGA boards?
