Zedboard Ethernet output
I 'm working on a projet on vivado that aim to display sensor images, i displayed them on an LCD screen using VGA and HDMI, now i like to display then on my PC through the ethenet output (I also created a software on QT por image processing)
so i want to know how to make the connexion between my software and the sensor data sent via ethernet.
Any tutorial or project plz !
Voyager
Voyager
Hey @mkooli,
now i like to display then on my PC through the ethenet output ...
There are a number of options here depending on the amount of data you want to transfer.
  • Copy the data via rsync/scp/tftp (either from device or from PC)
  • Install a simple web server on the device and access it from the PC software
  • Create a custom TCP server which sends the image data on request from the PC software
  • Have a realtime streaming server broadcast the data
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
@mkooli
In your specific case the best course of action will be to use a UDP multicast publisher on the Zynq side.
(There is a LWIP udp example in the SDK)
On the Linux/Windows side, you should use the usual sockets programming
http://www.tenouk.com/Module41c.html
The advantage is that you dont need to bother about connections and the switch will take care if you have several clients consuming the data.
HI @hbucher
I created the project now using a UDP multicast publisher, i want to know how can I verify if my frames are sent and how can I display them on my PC.
I'm lost especially that I 'm a biginner in Vivadi and SDK programming.
@mkooli
The easiest way is to set an ILA in the ethernet out and capture while it's still in the board.
Another method is connecting your board to your laptop/computer with a crossover ethernet cable (which is unlikely you have). If autocross is enabled on both devices you can use a normal patch cable so just try.  Otherwise you will need a hub/switch.
If green lights go on on both sides, you should be good to go. Fire SDK.
On the Linux/Windows laptop/computer, run wireshark and start capturing. Hopefully you should see the packets popping up in the screen.
Hi @hbucher,
It'seems ok for me, data packets are sent, now still the way to verify if there are the good frames data.
What I want really do, is displaying the frames on my Laptop screen, is there any software allowing this ?
Thanks !
@mkooli
Try Wireshark
https://www.wireshark.org/download.html
