Zync Ultrascale+ ZU2CG: PL-Ethernet solutions (SGMII)
Dear Xilinx-Members,
I chose the ZU2CG-derivate from the Ultrascale+-series for a new design. The ZU2CG has no SerDes-transceivers (GT) in the PL.
I checked the Ethernet solution AppNotes "xapp1305-ps-pl-based-ethernet-solution.pdf" and "pg047-gig-eth-pcs-pma.pdf".
As I understood, I have two possibilities to implement the SGMII-interface in the PL:
1) Using PS GEM through EMIO: This solutions requires GT's in the PL => The ZU2CG don't have them.
Thus, it is not possible with the ZU2CG.
2) Asynchronous SGMII over LVDS: This solution does support the embedded clock in the data stream. It don't require any GTs in the PL.
Thus, it can be implemented on the ZU2CG.
First question: Is my understanding correct?
Additionally, it is possible to use one of the GEMs in the PS to use SGMII (with embedded clock) and route internally the TX-data from the PL to the PS respectively the RX-data from the PS to the PL.
Next questions:
- If this is possible, is there any CPU-interaction required to transfer the SGMII-data from PS<=>PL or are these just DMA-transfers?
- What is the maximum latency for this transaction (PS<=>PL)?
Thanks in advance!
Julian
Re: Zync Ultrascale+ ZU2CG: PL-Ethernet solutions (SGMII)
Hi @dj_hbk ,
Yes, your understnading is correct. PS EMIO SGMII requires GTs on PL. And SGMII over LVDS might be a solutuon for you.
To consider using PS GEM SGMII using PS-GTR, can you please be more specific on your data flow? This is not supposed to go through PL but external SGMII PHY directly.
Hi @dj_hbk ,
Thank you nanz!
I want to connect two FPGAs with SGMII. One is the PL of the ZU2CG and the other one with SerDes-Transceivers.
The data I get from the second FPGA must be processed in the PL before this data goes to the PS.
So my question is, if I use the PS to connect the second FPGA via SGMII, how much latency and CPU-utilization will add up, when I first have to send this data to the PL of the ZU2CG?
Hello again,
can also confirm that we can use the GEMs from the PS-domain and share the data with the PL via FIFO:
https://www.xilinx.com/support/documentation/user_guides/ug1085-zynq-ultrascale-trm.pdf
=> Page 933
-GEM DMA engine as a master on the PS AXI interconnect (LPD) with a 32-bit data access width
-Slave interface in the PL via the external FIFO interface with an 8-bit data access width
