prabha-5g
Zynq Ethernet issue
I am using a custom FPGA board(XCZU28DR). I have issues interfacing ethernet chip with the FPGA.
We are using DP83867IRRGZR Ethernet chip connected in GEM3 in the PS (connections are similar to ZCU111 board)
I am getting the following errors when I boot the board
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete......................................... TIMEOUT !
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
Tags (3)
nanz
Hi @prabha-5g ,
Are you using RGMII MIO with GEM3 too? Could you please upload your DTS and bootlog to have a look?
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
shabbirk
Hi @prabha-5g
Can you check if boot.src file is copied into the SD card if you are booting from it? If not try copying this file too
Shabbir
prabha-5g
Hi nanz,
Please find the attached DTS, bootlog and the schematic file.
Prabha
prabha-5g
Hi Shabbrik,
I tried placing the boot.scr in addition to the UEnv.txt file in the sd card. I am getting the same error.
Prabha
shabbirk
Hi @prabha-5g
Rather than the ethernet issue, I believe you don't have the uboot environment variables. If the connections are same, can you try with the ZCU111 BSP flow once, I mean create a petalinux project with zcu111 BSP and then import your hdf file to build the project to see how it goes?
Shabbir
prabha-5g
Hi Shabbirk,
The pinout are different for UART in ZCU111 and my board. So i cannot use the same hdf file.
Can you suggest how i can access uboot environmental variables, and I create my files manually not using petalinux.
Attached is my current error log.
Prabha
prabha-5g
I could not download zcu111 BSP from the website, so I created a petalinux project with template.
And I see that eth0 is not found. I have set a static IP as I was getting BOOTP error messages.
What should I do further? Is there anything I am missing.
Prabha
