Novia
ZynqMP GEM1 connected to Marvell 88E1111S phy through SGMII doesn't work in u-boot.
The SOC we are using is zu102. GEM1 is connected to a phy through SGMII. This is using a 2019-02 u-boot.  After configure gem1 in device tree, eth0 can be deteted by "mii device" command. But zu102 can't be pinged successfully.
The phy we use is Marvell 88E1111S, which is 100/1000BASE-T1 interface. The device tree as below:
Since this is not a TI phy, I remove the TI related configuration.
what "is-internal-pcspma" means?
After system is started up, I can find the eth0.
 I also checked the pcs_status of gem0 (0xFF0B0204), whose value is 0x0000012D. It shows that the link status is up.
But ping/tftp are all failed.
From Debugging-Tips-when-using-GEM-on-Zynq-MPSoC-devices , most debugging tips is for kernel, I am not sure it is works for u-boot.
Besides, I dumped below registers. Any abnormal found?
I also tried phy loopback, it works well.
then I want to try mac loopback and pcs loopback, but the detail test procedure is not clear. Hope you can provide the details.
nanz
Hi @Novia ,
Please check the following post and see if it helps:
https://forums.xilinx.com/t5/Ethernet/Howto-configure-Linux-device-tree-for-Ethernet-with-TI-DP83867/td-p/1180952
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
nanz
Hi @Novia ,
