ZynqPS Ethernet issue on custom board
I have two custom boards built with the same Ethernet circuit available on ZCU102 board.
On one of the board i am able to verify the lwip echo server application. On the other board it gets stuck at "Start PHY autonegotiation" step and doesn't proceed further. Any steps/suggestions for debug should be very helpful
Mentor watari
Mentor
Re: ZynqPS Ethernet issue on custom board
Hi @trinadhkosuru
I suggest you to make sure MAC address.
I suspect that two custom board have same MAC address.
Best regards,
Each time i tested, powered ON only one board at a time. I didn't change the MAC address, Do i need to change even if i have only one board turned ON..?
Mentor watari
Mentor
Hi @trinadhkosuru
In some case, ex. using linux, you need to set indipendently mac address by something way.
Would you share how to use networking ? Using linux ? or other...
Best regards,
Seems to be a loose contact between fpga and base board. I am able to get the ethernet working ..Thanks
