after 10GEMAC IS interfaced to 10BASE_R, should i interface directly to SFP+ ??? or should i connect to GTX transceiver in VC707???
HAI
i have to interface 10GE MAC to SFP+ in vc707 board, i have learnt from here that, i have to first interface 10GEMAC with 10GBASE_R and then to SFP+.
10GBASE_R ip is available from vivado. in this IP there are lot of input/output ports regarding transreceiver, so i am confused , should i directly 10GBASE_R to sfp+ or should i connect to something else ??????????????
thanks and regards
 AKRAM
Re: after 10GEMAC IS interfaced to 10BASE_R, should i interface directly to SFP+ ??? or should i connect to GTX transceiver in VC707???
sir, i want to know wheather this 10GBASE_R has inbuild GTXE2 transceiver????? there are lot of signals like
gttxreset
gtrxreset
qplllock
qplloutclk
qplloutrefclk
drp_den_i
drp_dwe
these all are input to transreceiver, i dont know how to handle this signals,
do i have to interface transreceiver code before 10GBASE_R ???
Hi Akram,
You can directly connect the transceiver pins to the SFP+.
Find the required connection between the SFP+ and the corresponding FPGA pins in the below document.
Have a look at page 40.
http://www.xilinx.com/support/documentation/boards_and_kits/vc707/ug885_VC707_Eval_Bd.pdf
The status signal pins can be found from the schematic.
Satish
gttxreset
gtrxreset
qplllock
qplloutclk
qplloutrefclk
drp_den_i
drp_dwe
