Observer david_li1984
aurora 8b10b : possible to use rxrecclk to generate txusrclk & rxusrclk ?
I'm connecting a v5 board with a v6 board by aurora 8b10b cores. Two different reference clock are used for the two boards.   To get consistent valid rx data, I try to generate txusrclk & rxusrclk from rxrecclk on v5 which receives data.
In hardware debug, the signal channel_up of v5 keeps high most time,  but will drop at intervals due to hard error.
Further examination shows txbuferr is asserted.
Why? Is it right to use rxrecclk like this?
Re: aurora 8b10b : possible to use rxrecclk to generate txusrclk & rxusrclk ?
NO. Aurora 8B10B uses TXOUTCLK to generate both TXUSRCLK and RXUSRCLK.
Also, it can work for PPM difference of upto +/- 100ppm between channel partners if you are using standard_cc module provided with example design.
The transmitter TXUSRCLK must be derived from the REFCLK clock source for correct operation.  The RXRECCLK can only be used with the receiver path.
Thank you
