mistercoffee
bug with 10GE example code
I'm not sure where to report this. I was going to open a webcase but see I can't do that anymore. This seemed like the best place to put it.
In the 10GE core example code there is a bug in MAC_fifo_block.vhd. Lines 264-267 have the following code:
rx_axis_mac_aresetn_i => not reset or rx_axis_mac_aresetn;
tx_axis_mac_aresetn_i => not reset or tx_axis_mac_aresetn;
rx_axis_fifo_aresetn_i => not reset or rx_axis_fifo_aresetn;
tx_axis_fifo_aresetn_i => not reset or tx_axis_fifo_aresetn;
The or should be and. Otherwise the reset cannot be triggered by the aresetn alone as it is active low.
yenigal
Thanks for reporting this.
I will communicate this to the internal team and see that it gets fixed in the future version of the core.
Satish
