designer1918
charisk problem of Virtex5-85T GTP Transciver
Dear Xilinx Engineer:
I have used  "0" diff pair of 4 tile transmiters to transmit "tx_data_in" and receive them by the same tile receivers'
"0" diff pair, tile0_txusrclk20_i can driver the 4 tiles successfully and the line rate is 3.125Gbps.
The Verilog code is as following:
parameter idle = 16'h95BC;
always @(posedge tile0_txusrclk20_i)
begin
         if(!reset)begin
                   tile0_txdata0_i <= 0;
                   tile1_txdata0_i <= 0;
                   tile2_txdata0_i <= 0;
                   tile3_txdata0_i <= 0;
                   tile0_txcharisk0_i <= 2'b00;
                   tile1_txcharisk0_i <= 2'b00;
                   tile2_txcharisk0_i <= 2'b00;
                   tile3_txcharisk0_i <= 2'b00;
         end
         else if(!tx_fifo_valid)begin
                   tile0_txdata0_i <= idle;
                   tile1_txdata0_i <= idle;
                   tile2_txdata0_i <= idle;
                   tile3_txdata0_i <= idle;
                   tile0_txcharisk0_i <= 2'b01;
                   tile1_txcharisk0_i <= 2'b01;
                   tile2_txcharisk0_i <= 2'b01;
                   tile3_txcharisk0_i <= 2'b01;
         end
         else begin
                   tile0_txdata0_i <= tx_data_in;
                   tile1_txdata0_i <= tx_data_in;
                   tile2_txdata0_i <= tx_data_in;
                   tile3_txdata0_i <= tx_data_in;
         end
end
There are two problems when I used the ChipScope to capture the  tileX_rx_data0_i and tileX_rxcharisk as Pic_1 and
Pic_2 showing:
1. When the TX idle code is 16'h95BC, the RX idle code BC95 and 95BC are presented randomly in  tile0_rx_data0_i,
tile1_rx_data0_i,  tile2_rx_data0_i,  tile3_rx_data0_i by burning program every time. When the RX idle code is 95BC,
the upper byte and low byte of  the following tileX_rx_data0_i is coincided with the tx_data_in, but when the RX idle
code is BC95, the upper byte and low byte of the following tileX_rx_data0_i are reversed to the tx_data_in, so I need
to use the tileX_rxcharisk to recover the byte order of the tileX_rx_data0_i.
2. when the RX idle is 95BC, the related tileX_rxcharisk is righrt, but when the RX idle code is BC95, the related
tileX_rxcharisk is always "0", so that I can not use the  tileX_rxcharisk to sepetare the RX idle code and the RX
Additionally (not showing in the pictures), if I change the TX idle code to 16'hBC95 (with tileX_txcharisk0_i <=
2'b10), the RX idle code BC95 and 95BC are presented randomly in  tile0_rx_data0_i,  tile1_rx_data0_i,
tile2_rx_data0_i,  tile3_rx_data0_i by burning program every time.  When the RX idle code is 95BC,  the upper byte and
low byte of the following tileX_rx_data0_i are reversed to the tx_data_in, and the related tileX_rxcharisk is righrt.
When the RX idle code is BC95, the upper byte and low byte of  the following tileX_rx_data0_i is coincided with the
tx_data_in, and the related tileX_rxcharisk is always "0".
These problem are really borthering me, very thanks for your help!
venkata
Check if AR#25385 shows some relevance to your observations
http://www.xilinx.com/support/answers/25385.html
designer1918
designer1918
venkata
