emac ip
hello, I use eamc ip core to transmit data at Gbit. But I don't how long is the gaps that between two contious frames? 96ns? 8ns? And how many clock periods of 125MHz does it cost? Thanks a lot!
Re: emac ip
HI @xinxizyf ,
Please try to run the example design simulation provided with the tool. You should get the info after running the simulation.
