fmc phy 88E1111 is able to link up cannot ping
Hello, I'm doing a project using the hardware to impement the 1588 protocol. In this project we made an 88e1111 phy card, the RXD and the TXD are all 8bit, so I don't need the GMII2RGMII IP. The input and output interfarce are as follows:
beacause it is duplex, so I don't need to connect all pins.
I've set the ENET1 to the EMIO, the interfaces are as follows:image.png
After the board block design, I've tested the SDK Lwip echo server, and it works well.
Then I move it to the petalinux, my petalinux version is 2018.2, however, I met some troubles.
I've tried to add these codes to the system-user.dtsi:
&gem1 {
    local-mac-address = [00 0a 35 00 01 23];
    phy-handle = <&phy1>;
    status = "okay";
    xlnx,ptp-enet-clock = <0x69f6bcb>;
    xlnx,has-mdio = <0x1>;
         mdio {
            #address-cells = <1>;
            #size-cells = <0>;
                      phy1: phy@0 {
                       compatible = "marvell,88e1111";
                      device_type = "ethernet-phy";
                      reg = <0>;
Before this project, I've tried to use ZYNQ's ENET0 source , and I found that petalinux always set the Ethernet port to the zedboard's local Ethernet port, but not my FMC PHY CARD's Ethernet port, so I tried to set it to ENET1。
  Then I tried to start my zedbaord, the print message are as follows:
U-Boot 2019.01 (Nov 26 2019 - 14:16:56 +0000) Xilinx Zynq ZC702
CPU:   Zynq 7z020
Silicon: v3.1
Model: Zynq Zed Development Board
DRAM:  ECC disabled 512 MiB
MMC:   mmc@e0100000: 0
Loading Environment from SPI Flash... SF: Detected s25fl256s_64k with page size 256 Bytes, erase size 64 KiB, total 32 MiB
In:    serial@e0001000
Out:   serial@e0001000
Err:   serial@e0001000
U-BOOT for test_1126
Device: mmc@e0100000
Manufacturer ID: 3
OEM: 5344
Bus Speed: 50000000
Mode : SD High Speed (50MHz)
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
10912132 bytes read in 617 ms (16.9 MiB/s)
   Using 'conf@system-top.dtb' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel@1' kernel subimage
     Description:  Linux kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x10000104
     Data Size:    4140768 Bytes = 3.9 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00008000
     Entry Point:  0x00008000
     Hash algo:    sha1
     Hash value:   6a04c3ff663aeaf9edcb032ee01bcbd57c150661
## Loading ramdisk from FIT Image at 10000000 ...
   Trying 'ramdisk@1' ramdisk subimage
     Description:  petalinux-user-image
     Type:         RAMDisk Image
     Compression:  gzip compressed
     Data Start:   0x103f6d58
     Data Size:    6753949 Bytes = 6.4 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   635d8634c97bed7680c7b08cade1ebf91c0e3b21
   Trying 'fdt@system-top.dtb' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x103f30e4
     Data Size:    15282 Bytes = 14.9 KiB
     Architecture: ARM
     Hash algo:    sha1
     Hash value:   74a021e43fd70b0f83e592b9189e7f4c6c1aabc9
   Booting using the fdt blob at 0x103f30e4
   Loading Kernel Image ... OK
   Loading Ramdisk to 0798f000, end 07fffe9d ... OK
   Loading Device Tree to 07988000, end 0798ebb1 ... OK
Starting kernel ...
Linux version 4.19.0-xilinx-v2019.1 (oe-user@oe-host) (gcc version 8.2.0 (GCC)) #1 SMP PREEMPT Tue Nov 26 11:31:46 UTC 2019
OF: fdt: Machine model: Zynq Zed Development Board
bootconsole [earlycon0] enabled
Memory policy: Data cache writealloc
cma: Reserved 16 MiB at 0x1f000000
random: get_random_bytes called from start_kernel+0x80/0x3c4 with crng_init=0
percpu: Embedded 16 pages/cpu @(ptrval) s35916 r8192 d21428 u65536
Built 1 zonelists, mobility grouping on.  Total pages: 130048
Kernel command line: console=ttyPS0,115200 earlyprintk
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 486520K/524288K available (6144K kernel code, 204K rwdata, 1604K rodata, 1024K init, 132K bss, 21384K reserved, 16384K cma-reserved, 0K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
    lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0x(ptrval) - 0x(ptrval)   (7136 kB)
      .init : 0x(ptrval) - 0x(ptrval)   (1024 kB)
      .data : 0x(ptrval) - 0x(ptrval)   ( 205 kB)
       .bss : 0x(ptrval) - 0x(ptrval)   ( 133 kB)
rcu: Preemptible hierarchical RCU implementation.
rcu:    RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
        Tasks RCU enabled.
rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
efuse mapped to (ptrval)
slcr mapped to (ptrval)
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at (ptrval)
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at (ptrval), irq=17
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU0: Spectre v2: using BPIALL workaround
Setting up static identity map for 0x100000 - 0x100060
rcu: Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
CPU1: Spectre v2: using BPIALL workaround
smp: Brought up 1 node, 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x(ptrval)
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 25, base_baud = 3125000) is a `▒▒׋▒Led
console [ttyPS0] enabled
bootconsole [earlycon0] disabled
vgaarb: loaded
SCSI subsystem initialized
media: Linux media interface: v0.10
videodev: Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
FPGA manager framework
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Freeing initrd memory: 6596K
hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=30 max_order=17 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
io scheduler noop registered
io scheduler mq-deadline registered
io scheduler kyber registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
brd: module loaded
loop: module loaded
m25p80 spi0.0: found s25fl256s1, expected n25q512a
m25p80 spi0.0: s25fl256s1 (32768 Kbytes)
4 fixed-partitions partitions found on MTD device spi0.0
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000fa0000 : "kernel"
0x000000fa0000-0x000002000000 : "spare"
libphy: Fixed MDIO Bus: probed
CAN device driver interface
macb e000b000.ethernet: invalid hw address, using random
libphy: MACB_mii_bus: probed
Marvell 88E1510 e000b000.ethernet-ffffffff:00: attached PHY driver [Marvell 88E1510] (mii_bus:phy_addr=e000b000.ethernet-ffffffff:00, irq=POLL)
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 27 (c6:72:9c:d8:5e:2b)
[Firmware Warn]: /amba/ethernet@e000c000/mdio/phy@1: Whitelisted compatible string. Please remove
Marvell 88E1111 e000c000.ethernet-ffffffff:00: attached PHY driver [Marvell 88E1111] (mii_bus:phy_addr=e000c000.ethernet-ffffffff:00, irq=POLL)
macb e000c000.ethernet eth1: Cadence GEM rev 0x00020118 at 0xe000c000 irq 28 (00:0a:35:00:01:25)
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci-pci: EHCI PCI platform driver
chipidea-usb2 e0002000.usb: e0002000.usb supply vbus not found, using dummy regulator
chipidea-usb2 e0002000.usb: Linked as a consumer to regulator.0
ULPI transceiver vendor/product ID 0x0451/0x1507
Found TI TUSB1210 ULPI transceiver.
ULPI integrity check: passed.
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
i2c /dev entries driver
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at (ptrval) with timeout 10s
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbhid: USB HID core driver
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
NET: Registered protocol family 10
Segment Routing with IPv6
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
can: controller area network core (rev 20170425 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20170425)
can: broadcast manager protocol (rev 20170425 t)
can: netlink gateway (rev 20170425) max_hops=1
of-fpga-region fpga-full: FPGA Region probed
hctosys: unable to open rtc device (rtc0)
of_cfs_init
of_cfs_init: OK
ALSA device list:
  No soundcards found.
Freeing unused kernel memory: 1024K
Run /init as init process
mmc0: new high speed SDHC card at address aaaa
INIT: mmcblk0: mmc0:aaaa SU08G 7.40 GiB
 mmcblk0: p1
version 2.88 booting
Starting udev
udevd[765]: starting version 3.2.5
random: udevd: uninitialized urandom read (16 bytes read)
udevd[766]: starting eudev-3.2.5
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
hwclock: can't open '/dev/misc/rtc': No such file or directory
Tue Nov 26 14:17:21 UTC 2019
urandom_read: 2 callbacks suppressed
random: dd: uninitialized urandom read (512 bytes read)
Configuring packages on first boot....
 (This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
 Removing any system startup links for run-postinsts ...
  /etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc: started, v1.29.2
udhcpc: sending discover
udhcpc: no lease, forking to background
done.
Starting Dropbear SSH server: random: dropbearkey: uninitialized urandom read (32 bytes read)
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCZH5eBihs5u4v6lbGqaYp1I9Dj6sFo3vqGuKcKSBgUDqdH2zfLgZIRERp0uU3UFG53random: dropbear: uninitialized urandom read (32 bytes read)
4hm/O++lj/TPSBNbf2gbNJfi3ENWdvsC6nEyxJLC+MeaBXpgQ7Zrpy2kGucUX/lY11euxBAcYNkS3zlaP1+JYRv0IoRB10R0aSJUxdIX+qAp+IP0+HFua390zAOHoUsmCCWln4WHI58ba3AcZ+w9yLDaJWpZuxFAu4lhlZq5iwMowRbBmn2418y2BUNqYqCKrdbT1ZHL+lO06V4Vlrr+jAkvJ8hCWcew8lmvFEO/To+BC0Lgvqyjx0CO7EB2EOTpApF+MJ6yeyEoJLMEs72J root@test_1126
Fingerprint: sha1!! e5:a0:ad:ce:87:23:a7:67:c9:02:d9:b9:62:60:49:7a:7f:5d:0a:f3
dropbear.
Starting internet superserver: inetd.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2019.1 test_1126 /dev/ttyPS0
After the system started, when I import "ifconfig", message are as follows:
Firstly , it won't show the eth1, when I config the eth1:
It shows "Link up (1000 full)", however it cannot ping to the host. I've ensured that the host ip is 192.168.1.102.
However, when I use the zedboard's local ehternet port, although I'd never config it, it works well.
And my FMC card's 1000M speed led and RX led could work well
so how should I solve this problems? Thanks all of the responders.
