gtrefclk in ZCU102 board
Hello all,
I want to use the SFP that are already in my board ZCU102. So after instantiate the 1G/2.5G PCS/PMA IP, I needed to connect the gtrefclk to a physical constraint. So I checked in the schematic which pins were suitable to connect this clock, and I found that pin G27, called FMC_HPC1_GBTCLK0_M2C_C_N, but I don't know if I can connect the clock in this pin or if it is only for SFP-FMC modules.
Which other pins can I use for constraint this clock?
Thanks and best regards,
baldrism
Re: gtrefclk in ZCU102 board
X1Y3 is on the other side of the FPGA from X0Y4.  They are incompatible.   This tends to happen when you have set up a physical location for the GT channel in the wizard and try to change it by adding locs to the design.  There will be a clash of locations.  Go back to investigate the wizard placement.
  I use the default assignment from xapp1305 which uses the C8 pin as follows:
  set_property PACKAGE_PIN C8 [get_ports gtrefclk_in_clk_p]
  create_clock -period 8.000 -name gt_ref_clk [get_ports gtrefclk_in_clk_p]
  This is MGETREF clock for Bank 230 and it works just fine.
  HTH,
Luca
Hello @colombini_luca,
Thank you to reply. I have tried your proposal but I get this warning:
Have you ever seen these warnings?
Thank you,
baldrism
Hi @baldrism,
I am not getting that warning so far.
Luca
