09-17-2014 02:00 AM
in the 7 series FPGAs Transceiver Wizard (3.3) the GUI fails to display the quad setup when I choose REFCLK0 for TX CLOCK SOURCE. See the image in the appendix.
When I change back to REFCLK1 the quad setup reappears.
Furthermore, when I change the TX PLL or the gt row back and forth the TX CLOCK SOURCE is automatically set back to REFCLK1.
Related questions:
What exactly does the selection of TX CLOCK SOURCE do to the code?
Should it change the PLL?REFCLKSEL port in the common file? I checked these two ports for different selections in the IP example and they are always both set to "001"?
Is the manual edit of these ports the same as choosing TX CLOCK SOURCE?
Where else can I verify that the change of TX CLOCK SOURCE is really implemented?
09-17-2014 09:05 AM
09-17-2014 11:17 AM
A: Based on the TX CLOCK SOURCE, the output of the IBUFDS_GTE2 of a specific quad is routed to respective neighbouring quads or the same quad, based on this selection. Check the image below
09-17-2014 11:56 AM
09-18-2014 08:13 AM
Thanks for the answers.
I use Gentoo but I could reproduce the error on a Windows machine. You need to enable more than one channel and then change TX CLOCK SOURCE.
I use Artix 7-device, yes.
Maybe someone could answer these questions:
Is the manual edit of the PLL?REFCLKSEL ports in the common file the same as choosing TX CLOCK SOURCE in the wizard?
Where can I verify that the change of TX CLOCK SOURCE is really implemented?
09-18-2014 10:40 PM
09-19-2014 01:55 PM
I'm just now seeing something similar, except I'm only using 5 receivers Y32-35 and Y36, both
with QPLLs sharing the Q8 REFCLK .
Maybe if you experiment too much with the quad clock configuration the wizard gets confused
and loses the plot? (Win 7)
After messing around some more, I thought I had the quad display back, but after closing
and reopening the project/IP the quad display was still blank. Guess I'll start again from
scratch with no experiments and see what happens.
