if GTXE2_COMMON should be instantiated?
FPGA: V7
when generate a gig-pcs-pma core, I can find the GTXE2_COMMON is used in code.
But from pg047 page141, there isn't GTXE2_COMMON for v7 FPGA (only A7 use it)?
So if I can delete it manuaaly?
Re: if GTXE2_COMMON should be instantiated?
What is the exact part you are using?
Virtex-7 devices have GTX resources. Check this http://www.xilinx.com/publications/prod_mktg/Virtex7-Product-Table.pdf
Deepika.
Deepika.
You cannot remove the GTXE2_Common in the user code.
It is required for passing the correct BIAS_CFG value.
If you are using multiple SGMII cores in the same quad then a single GTXE2_common is enough.
Have a look at the below AR>
http://www.xilinx.com/support/answers/43339.html
Satish
