Anonymous
Not applicable
implementing TEMAC core on spartan3e board (without processord)
hi
I just want to start implementing temac example design on the spartan3e board. as I dont find the xilinx's documents useful, I would appreciate if you help me step by step. here are my questions :
1- should I use DCM to generate required clocks? if no, how should I generate them?
2- Is the reset in example desing active low?
3- how can I test temac core working? (How can I ping when my board does not have IP?)
4- how can I measure temac performance?
5- any other recommendation?
sorry for my bad english and thanks in advance.
Anonymous
Not applicable
Re: implementing TEMAC core on spartan3e board (without processord)
and another step forward :))
when I ping I can not capture the pakets that come from board. so I write a simple socket in c. I create a raw socket to send packets in datalink layer (and to the MAC address which I choose for my board) and now I can recive the packets I've sent to the board. and everything is ok!
When you say "temac example design" I assume you are talking about the one generated from CoreGen. If yes, the example design includes testbench as well as implementaion scripts. I suggest you play with the example a little bit to understand how things work
To debug any Ethernet design, a network snipper will come handy. I would recommend a free tool called "wireshark" ( http://www.wireshark.org ). The example design loops back packets.  When you connect the board to your PC, the PC will automatically send some packets (e.g. ARP packets). If you see the packets coming back from the board in wireshark, you will know that the TEMAC core works in the FPGA.
Regarding the performance, you may want to contact the tech supoort to get an earlier version of xapp1026 that includes a reference design for Spartan3E.
@Anonymous wrote:
hi
Cheers,
Jim
Anonymous
Not applicable
thanks for your reply.
yes I am working with example design which coregen has generated. I generate the core without host and with MII. in my code I assign the configuration vector. but when I download the bitstream none of the LEDs are on.
what do you suggest me to do?
Which board? Which LEDs? The first thing I would check is to make sure that LOC constraints for all IOs in the UCF match the board.
Cheers,
Jim
Anonymous
Not applicable
I am working on my own board which has a spartan3e FPGA. I've checked its ethernet peripheral with microblaze before. this board has a smsc LAN83C185 phy and 3 LEDs. 1-Link On indication.Active indicates that the Link
(100Base-TX or 10Base-T) is on 2-ACTIVITY indication. Active indicates that there is Carrier sense (CRS) from the active PMD. 3-speed 100 indication
I check my UCF file and it's ok.
I configure my temac core with configuration vector.
Anonymous
Not applicable
one step forward ...
I have some problem with the reset now I fix it and all my three LEDs are on. but I can not capture any packets from my board. I appreciate your suggestions ...
Anonymous
Not applicable
