05-03-2019 11:20 AM
Does Xilinx has an Infiniband IP. I'm just scratching the surface right now and want to communicate with a HOST that has a Mellanox NIC card that plug into a PCIE slot with a QSFP28 which is Infiniband port.
I was to know if my FPGA (possible Ultrasacle) can interface to this port and recieved and transmit data packet.at a very low level and access the payload. Much like the Xilinx PCIe IP over the AXI-bus?
05-04-2019 02:10 PM
hi @tchin123 .
i believe and assume that we do not have this IP ,but With Ethernet solutions from 1M to 400G, PCI Express from Gen1x1 to Gen3x16, and a range of other interface IPs that can run up to 25G, we can meet your bandwidth needs i believe .
05-07-2019 07:20 AM
I found that Polybus System Corporation has Infiniband IP core for the 7-series FPGA. I don't see this in the Vivado IP Catalog.
05-07-2019 11:56 PM
hi @tchin123 ,
yes this IP is not found vivado tool IP catlog , hence this is not offically support by us
