is SGMII LVDS supported in ZYNQ Z-7007S and Z-7010 -2 devices
I have a customer that would like to use the 1G/2.5G Ethernet PCS/PMA or SGMII v16.1 IP  with LVDS in a small ZYNQ device.
According to PG047 table 3-2 XC7Z010/XC7Z020 in speed grade -2 are supported. Is this supported in the CLG225 package ?
Although the XC7Z007S is not specified in table 3-2, can the IP be targeted to this device is -2 speed grade also ?
They are looking for a small footprint and want to implement this IP.
Thanks for your help.
Re: is SGMII LVDS supported in ZYNQ Z-7007S and Z-7010 -2 devices
XC7Z007S CLG225  speed grade -2 supports SGMII over LVDS.
You can check same in vivado select your FPGA device, add IP from IP catalog and check configuration.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Pratap
Thank you for confirming !
