is phyad fixed for pca_pma core
when generate ge-pcs-pma core, we can input phy address value. just like attach shows.
I want to know if this value can not be changed in user code?
if in my design, there are 32 ge input ports, so I need instantiate 32 pcs-pma core. If I want to configure them through mdio, I need to know the core's phyad value. So if the value can not be changed by user, then does it mean I have to generate 32 pcs-pma core one by one?
Re: is phyad fixed for pca_pma core
I believe you need to regenerate the core if any parameter will change in coregen GUI including the phy address.
Thanks and Regards
Balkrishan
er,,,,I used this core in v6, it can set phyad by user manaully. But for v7,why it is fixed? I believe it will be a huge work to generate so many cores.
