shreyas_borse
issue : unable to connect multiple PC on Quad FMC ethernet.
Hello
I am trying to build Quad- gig- AXI-Ethernet on PicoZed FMC carrier V2 and SOM 7030 and OP031 and (1.8V version): OP031-1V8 (installed drivers CP210x) vivado version 18.02 on ubuntu 16.0
I Followed the steps mentioned in these links.
i am able to ping from 1 Windows pc to FMC board (port0-eth1) and vice versa ,
however when i connect the other pc to FMC port 1-eth2 and try to ping it shows : request timed out on 2nd pc but at the same time i am able to ping from board to the 2nd pc!.
I followed the github
repo and it's working for 1 port : do i need to modify those so that i can ping from 2nd pc to board too(Port1-eth2).?
patocarr
Hi @shreyas_borse
  The ifconfig command is old and deprecated, the new command is "ip" from the iproute2 package. What's the output of:
ip link
ip address
ip route
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
shreyas_borse
Thanks Pat,
But they can be used on petalinux?
as the Zedboard 7030 built with Petalinux
patocarr
@shreyas_borse
  I've been using it in Petalinux with ZynqMP without any special configuration. I assume it will be available in Zynq-7000 but may need to be enabled explicitly.
-Pat
shreyas_borse
@patocarr  Thanks alot i ressolved it using ipforwarding / bridging
bitjockey
Were you trying to use 1 IP address/subnet for all 4? Or unique subnets and IPs per port?  Was your route table set up properly too?  If you're doing bridging it's just acting like a 4 (5 w/ the CPU) port switch and doing MAC learning for the packets and ignore IP.
shreyas_borse
port 1 --- 192.168.1.11; port 2 --- 192.168.1.21......... and everything was on ...1.1 network
bitjockey
Yeah, Linux probably not happy that all four ports were in the same /24 subnet.  It was probably routing all traffic out one port.  If you'd had 192.161.1.11 and .2.21 and .3.31 etc. (assuming a mask of 255.255.255.0) it may be better.  Did pc1 see pc2's packets (or their replies) in wireshark?
shreyas_borse
I Haven't tried that!
