Visitor swa_mi
jesd example design
hi,
I selected the jesd204 ip from the ip catalog and customized it .
After that I right clicked on the .xci file under the design sources tab and generated an example design.
Will the example design contains exact parameters as that of jesd204 ip that I configured and customized ?
Re: jesd example design
Hi @swa_mi
Example design contains same configuration, double click on .xci in example design and can be check the configuration options.
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Observer yawenluo16
Hey, do you know where can find the JESD Example Design?. I've searched for the JESD Example Designs for so long, found several posts in the Forum mention that the JESD Lounge have the examples, but I just could not find it. Am I missing something? Please, help ......
hi @swa_mi ,
There is no hardware demo design as such for JESD IP .But you can follow these step to make an example design .
1) Configure the IP as required to interface with your convertor.
2) Open the IP example design in Vivado.
3) Use this as a starting point and edit as required.
You will need to modify the signal generator / mapper (for DAC) or demapper (ADC) to suit the convertor you are using.
Rahul Khatri
Please Kudo or Accept as a solution, If this Post helped you.
Observer yawenluo16
Thanks for your time, appreciate it!
