silat14
lwIP Application Project Ping Error on Zynq Board
I tried to apply this project on my custom Zynq Ultrascale+ board. I just changed phy_link_speed as 100Mbps from Autodetect (in temac_adapter_options/BSP's Settings) I get the message in terminal:
-----lwIP TCP echo server ------
TCP packets sent to port 6001 will be echoed back
link speed for phy address 0: 100
DHCP Timeout
Configuring default IP of 192.168.1.10
Board IP: 192.168.1.10
Netmask : 255.255.255.0
Gateway : 192.168.1.1
TCP echo server started @ port 7
So application was running successfully, however when I applied the ping step I get the:
connect: Network is unreachable
and that's all, it stops. Should I modify some settings for Zynq in SDK? I appreciate to any help.
Thanks in advance.
shabbirk
Hi @silat14
We have this XAPP1306, targeting zynqMP LWIP ethernet application. This could be a good start if you want to implement LWIP
https://www.xilinx.com/support/documentation/application_notes/xapp1306-ps-pl-ethernet-performance-lwip.pdf
Best Regards
Shabbir
pvenugo
Hi @silat14 ,
In standalone BSP setting for lwip TCP echo server these are the recommended settings.
LIBRARY_NAME = lwip211
API_MODE = RAW_API
dhcp_does_arp_check = true
lwip_dhcp = true
ipv6_enable = false
pbuf_pool_size = 2048
Praveen
shengjie
Hi @silat14 ,
Can you check the ip address on the PC. It should be 192.168.1.xxx which is different with 192.168.1.10.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
silat14
Hello @pvenugo ,
Thank you for your answer. I checked all settings you write. All of them are same as mine.
Best regards.
silat14
Hello @shengjie ,
Thank you for your answer , I changed the IP adress as 192.168.1.8. and  tried to ping 192.168.1.10 but unfortunatelly it did'nt work. I got this error:
ping 192.168.1.10
PING 192.168.1.10 (192.168.1.10) 56(84) bytes of data.
From 192.168.1.8 icmp_seq=1 Destination Host Unreachable
From 192.168.1.8 icmp_seq=2 Destination Host Unreachable
From 192.168.1.8 icmp_seq=3 Destination Host Unreachable
^C
--- 192.168.1.10 ping statistics ---
6 packets transmitted, 0 received, +3 errors, 100% packet loss, time 5031ms
pipe 3
Then I decided to apply echo server project on my ZYnq Ultrascale+ MPSoc Evalution Board(ZCU106) but when I tried to create echo server application project in SDK I got the error again as :
This application requires an Ethernet MAC IP instance in the hardware.
and couldn't even create the project. I appreciate any help. Thanks in advance.
shengjie
Hi @silat14 ,
Which interface you are using? PS GEM or PL AXI-Ethernet?
Can you share some screenshots for configuration of Zynq MPSoC Core?
The GEM3 should be enabled.
