Observer cforney
lwip library fails compile with ethernet lite
The lwip202_v1_1 fails to build when using a design with the axi_ethernetlite.  It appears that the ethernet lite is not recognized as a supported device in eth_link_detect in xadapter.c and a valid xemacp and xemacs are not defined within the #if statement.  Are there any workarounds?lwip compiler error.PNG
Re: lwip library fails compile with ethernet lite
Could you please try to set a local repository with the modification files in SDK? BSP will get re-generated everytime if you update or clean up/regenerate the designs.
Hi @cforney,
Which version of the Vivado/SDK you are using?
This is an known issue that after the upgrade to lwip202 in the 2018.1 release, some additional PHY related functionality was added in Vivado 2018.2, which has caused Emaclite functionality not to work.
In 2018.2 builds, designs with Emaclite will throw up compilation errors.
Please use the attached patch for 2018.2.
Observer cforney
I did create this using 2018.2.  That worked for the compile issue.
I'm working in a windows environment so I just added to the BSP source in my SDK project.  How do I prevent the BSP from being regenerated every time I recompile or update the vivado project.
Unfortunately the phy is failing to autonegotiate, but that's another conversation.
Observer cforney
I needed to modify one more line of code in xemacliteif.c.  In the get_IEEE_phy_speed_emaclite, when the code sets the autonegotiate advertise register to 100 and 10, it inadvertently clears the advertise IEEE 802.3 bit and my PHY just sat there and failed to autonegotiate.  (I'm using a TI DP83848K dev board.) So I just added the bit mask to make sure it is advertised.  It's probably better to read the register and OR in the desired speeds.
Old Code:
/* Advertise PHY speed of 100 and 10 Mbps */
XEmacLite_PhyWrite(xemaclitep, phy_addr,
                       IEEE_AUTONEGO_ADVERTISE_REG,
                       (ADVERTISE_100_AND_10));
New Code:
                       (ADVERTISE_100_AND_10 | 0x0001));
Visitor lancou
Hi, this might be a silly question, but how exactly do I use this patch? Encountered the same problem.
Observer cforney
Not at all.  I'm not a Linux expert and wasn't sure how to patch the code.  But since I use the windows, I opened up the .patch file with a text editor which contains the output of the "diff" command.  All of the lines with a '+' are the lines that need to be added to xadapter.c in your lwip_bsp.  I copied them below with approximate line numbers.  You're adding an #elsif to the #if directives for whatever interface was used in the design.  Somehow the ethernet lite got removed in 2018.2
Modify  xadapter.c
In Project bsp->ps7_corexa9_0->libsrc->lwip202_v1_1->src->contrib->ports->Xilinx->netif
Around line 300 add the following to define phy_link_detect
#elif defined(XLWIP_CONFIG_INCLUDE_EMACLITE)
static u32_t phy_link_detect(XEmacLite *xemacp, u32_t phy_addr)
                u16_t status;
                /* Read Phy Status register twice to get the confirmation of the current
                 * link status.
                XEmacLite_PhyRead(xemacp, phy_addr, IEEE_STATUS_REG_OFFSET, &status);
                if (status & IEEE_STAT_LINK_STATUS)
                                return 1;
                return 0;
Around line 348 add the following to define eth_link_detect
static u32_t phy_autoneg_status(XEmacLite *xemacp, u32_t phy_addr)
                u16_t status;
                 * link status.
                if (status & IEEE_STAT_AUTONEGOTIATE_COMPLETE)
                                return 1;
                return 0;
 and around 377 add the following to define xemapcs and xemapp in void eth_link_detect
                                xemacliteif_s *xemacs = (xemacliteif_s *)(xemac->state);
                                XEmacLite *xemacp = xemacs->instance;
In get_IEEE_phy_speed_emaclite()
Modify bit mask to keep the advertise IEEE 802.3 capabilities
Good luck!
Observer matthiaskern
Can we expect a software-update for this bugfix any time soon? The patch-file is not a very handy solution
