need 100G Ethernet subsystem example design
I am unable to find the source code for the example design of the cmac_uplus  mentionned in the PG203.
even in vivado 2017.2 the open example design tab is disabled?
Any suggestion?
Re: need 100G Ethernet subsystem example design
Have you selected the xci file and right clicked to find the Open IP example design.
If generated the core in OOC then the option will be enabled once the runs are done.
Upload the snapshot if you still don't see the open IP example design option.
Satish
Satish
I generated the output products and waited until the synthesis of the block to be completed, then i was able to get the files. Thanks for the answer.
Cheers,
