problem SGMII IP VC707 receiver path
I'm trying to use the SGMII IP for the VC707 fpga board to establish a connection between my PC and my FPGA board.
I instantiated the SGMII IP and opened the example design i wrapped the example design in a TOP module.
I constrained the design with the following xdc file ( i modified the xcd file generated by the example design)
# The following constraints target the Transceiver Physical*
# Interface which is instantiated in the Example Design.   *
# Transceiver I/O placement:                               -
# Place the transceiver components, chosen for this example design
# *** These values should be modified according to your specific design ***
set_property LOC GTXE2_CHANNEL_X1Y27 [get_cells */*/*/*/transceiver_inst/gtwizard_inst/*/gtwizard_i/gt0_GTWIZARD_i/gtxe2_i]
(Maybe this line is not suited fo the VC707?? ) #*********************************************************** # The following constraints target the GMII implemented in * # the Example Design. * #*********************************************************** # The GMII is intended to be an internal interface. * # The GMII signals should be connected directly to user * # logic and all of the following constraints in this file * # should be removed. * #*********************************************************** set_property PACKAGE_PIN AH7 [get_ports SYS_CLK_N] set_property PACKAGE_PIN AH8 [get_ports SYS_CLK_P] set_property IOSTANDARD LVDS [get_ports independent_clock_bufg_n] set_property PACKAGE_PIN E18 [get_ports independent_clock_bufg_n] set_property PACKAGE_PIN E19 [get_ports independent_clock_bufg_p] set_property IOSTANDARD LVDS [get_ports independent_clock_bufg_p] set_property PACKAGE_PIN AP40 [get_ports RESET] set_property IOSTANDARD LVCMOS18 [get_ports RESET] set_property PACKAGE_PIN AV39 [get_ports PHY_RESET_N] set_property IOSTANDARD LVCMOS18 [get_ports PHY_RESET_N] set_property PACKAGE_PIN AR40 [get_ports RESET1] set_property IOSTANDARD LVCMOS18 [get_ports RESET1] set_property PACKAGE_PIN AM39 [get_ports LED] set_property IOSTANDARD LVCMOS18 [get_ports LED] set_property PACKAGE_PIN AM7 [get_ports RXN] set_property PACKAGE_PIN AM8 [get_ports RXP] set_property PACKAGE_PIN AN1 [get_ports TXN] set_property PACKAGE_PIN AN2 [get_ports TXP] set_property PACKAGE_PIN AJ33 [get_ports PHY_RESET] set_property IOSTANDARD LVCMOS18 [get_ports PHY_RESET]
I connected the ethernet cable to the PC and to the FPGA board, and then i type a ping command in the cmd window of my PC and i expect to see a rising edge on the signal gmii_rx_dv but nothing happens on the ILA debug core that i added
The trigger on the rising edge of gmii_rx_dv never happens
I don't know what to do, i verified that the design met the timing requirements
Does anyone have any idea?
Here is my TOP level vhd file
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
Library UNISIM;
use UNISIM.vcomponents.all;
entity Top is
    Port (
        -- Clocks
        SYS_CLK_P             : in std_logic;     -- 125 Mhz
        SYS_CLK_N             : in std_logic;     -- 125 Mhz
        independent_clock_bufg_p : in std_logic;
        independent_clock_bufg_n : in std_logic;
        RESET                 : in std_logic;     -- Reset
        RESET1                : in std_logic;
        PHY_RESET_N             : in std_logic;
        LED                   : out std_logic;
        PHY_RESET             : out std_logic;
        TXP                   : out std_logic;
        TXN                   : out std_logic;
        RXP                   : in std_logic;
        RXN                   : in std_logic
end entity Top;
architecture IMPL of Top is
component debounce IS
  GENERIC(
    counter_size  :  INTEGER := 20); --counter size (19 bits gives 10.5ms with 50MHz clock)
  PORT(
    clk     : IN  STD_LOGIC;  --input clock
    button  : IN  STD_LOGIC;  --input signal to be debounced
    result  : OUT STD_LOGIC); --debounced signal
END component debounce;
component gig_ethernet_pcs_pma_0_example_design is
      port(
      --An independent clock source used as the reference clock for an
      --IDELAYCTRL (if present) and for the main GT transceiver reset logic.
      --This example design assumes that this is of frequency 200MHz.
      independent_clock    : in std_logic;
      -- Tranceiver Interface
      gtrefclk_p           : in std_logic;                     -- Differential +ve of reference clock for tranceiver: , very high quality
      gtrefclk_n           : in std_logic;                     -- Differential -ve of reference clock for tranceiver: , very high quality
      rxuserclk2           : out std_logic;                     -- Differential -ve of reference clock for tranceiver:, very high quality
      txp                  : out std_logic;                    -- Differential +ve of serial transmission from PMA to PMD.
      txn                  : out std_logic;                    -- Differential -ve of serial transmission from PMA to PMD.
      rxp                  : in std_logic;                     -- Differential +ve for serial reception from PMD to PMA.
      rxn                  : in std_logic;                     -- Differential -ve for serial reception from PMD to PMA.
      -- GMII Interface (client MAC <=> PCS)
      sgmii_clk            : out std_logic;                    -- Clock for client MAC
      sgmii_rx_clk         : out std_logic;                    -- Clock for client MAC
      gmii_txd             : in std_logic_vector(7 downto 0);  -- Transmit data from client MAC.
      gmii_tx_en           : in std_logic;                     -- Transmit control signal from client MAC.
      gmii_tx_er           : in std_logic;                     -- Transmit control signal from client MAC.
      gmii_rxd             : out std_logic_vector(7 downto 0); -- Received Data to client MAC.
      gmii_rx_dv           : out std_logic;                    -- Received control signal to client MAC.
      gmii_rx_er           : out std_logic;                    -- Received control signal to client MAC.
      -- Management: Alternative to MDIO Interface
      configuration_vector : in std_logic_vector(4 downto 0);  -- Alternative to MDIO interface.
      -- Speed Control
      speed_is_10_100      : in std_logic;                     -- Core should operate at either 10Mbps or 100Mbps speeds
      speed_is_100         : in std_logic;                     -- Core should operate at 100Mbps speed
      -- General IO's
      status_vector        : out std_logic_vector(15 downto 0); -- Core status.
      reset                : in std_logic;                     -- Asynchronous reset for entire core.
      signal_detect        : in std_logic                      -- Input from PMD to indicate presence of optical input.
end component gig_ethernet_pcs_pma_0_example_design;
    -- signals
    -- Connect the following signals to 1G/2.5G Ethernet PCS/PMA or SGMII
    -- PHY_Speed is connected to status_vector(11 downto 10)
    signal tb_PHY_Speed        : std_logic_vector(1 downto 0); -- "11" Reserved, "10" 1000 Mb/s, "01" 100 Mb/s, "00" 10 Mb/s
    signal GMII_RXDV        : std_logic;
    signal GMII_RXD         : std_logic_vector(7 downto 0);
    signal GMII_RXERR       : std_logic;
    signal GMII_TXEN        : std_logic;
    signal GMII_TXD         : std_logic_vector(7 downto 0);
    signal tb_gmii_txd      : std_logic_vector(7 downto 0);
    signal tb_gmii_tx_en    : std_logic;
    signal tb_gmii_tx_er    : std_logic;
    signal tb_gmii_rxd      : std_logic_vector(7 downto 0);
    signal tb_gmii_rx_dv    : std_logic;
    signal tb_gmii_rx_er    : std_logic;
    signal tb_speed_is_10_100   : std_logic;
    signal tb_speed_is_100      : std_logic;
    signal tb_clk           : std_logic;
    signal tb_reset           : std_logic;
    signal tb_independent_clock_bufg           : std_logic;
    signal tb_mac_clock           : std_logic;
    signal tb_rxuserclk2             : std_logic;
    signal tb_rx_config              : std_logic_vector(79 downto 0);
    signal tb_tx_config              : std_logic_vector(79 downto 0);
    signal tb_s_rx_axis_fifo_tvalid  : std_logic;
    signal detect_edge : std_logic_vector( 1 downto 0);
    signal tb_s_arp_pkt_count : std_logic_vector(7 downto 0);
    signal tb_start : std_logic;
begin
   IBUFDS_inst : IBUFDS
   generic map (
      DIFF_TERM => FALSE, -- Differential Termination
      IBUF_LOW_PWR => TRUE, -- Low power (TRUE) vs. performance (FALSE) setting for referenced I/O standards
      IOSTANDARD => "DEFAULT")
   port map (
      O => tb_independent_clock_bufg,  -- Buffer output
      I => independent_clock_bufg_p,  -- Diff_p buffer input (connect directly to top-level port)
      IB => independent_clock_bufg_n -- Diff_n buffer input (connect directly to top-level port)
    gig_ethernet_pcs_pma_0_example_design_INST :  gig_ethernet_pcs_pma_0_example_design
      port Map(
      independent_clock               => tb_independent_clock_bufg,
      -- Transceiver Interface
      gtrefclk_p                      => SYS_CLK_P,
      gtrefclk_n                      => SYS_CLK_N,
      txp                             => txp,
      txn                             => txn,
      rxp                             => rxp,
      rxn                             => rxn,
      rxuserclk2                  => open, --tb_mac_clock,
      -- GMII Interface               -- GMII Interface
      sgmii_clk                       => open,
      sgmii_rx_clk                    => open,
--      gmii_txd                        => gmii_txd,
--      gmii_tx_en                      => gmii_txen,
--      gmii_tx_er                      => '0',
--      gmii_rxd                        => gmii_rxd,
--      gmii_rx_dv                      => gmii_rxdv,
--      gmii_rx_er                      => gmii_rxerr,
      gmii_txd                        => tb_gmii_txd    ,
      gmii_tx_en                      => tb_gmii_tx_en  ,
      gmii_tx_er                      => tb_gmii_tx_er  ,
      gmii_rxd                        => tb_gmii_rxd    ,
      gmii_rx_dv                      => tb_gmii_rx_dv  ,
      gmii_rx_er                      => tb_gmii_rx_er  ,
      -- Management: Alternati        -- Management: Alternati
      configuration_vector            => "00000",
      -- Speed Control                -- Speed Control
      speed_is_10_100                 => '0',
      speed_is_100                    => '0',
      -- General IO's                 -- General IO's
      status_vector                   => open,
      reset                           => tb_RESET,
      signal_detect                   => '1'
    debounce_INST : debounce
    PORT MAP(
        clk             => tb_independent_clock_bufg,
        button          => RESET,
        result          => tb_reset
    PHY_RESET <= not (PHY_RESET_N);
end architecture;
It's been a couple of weeks allready that i have this problem and don't know how to solve it
Re: problem SGMII IP VC707 receiver path
I finally found the solution, i had to enable the option auto negotiation in the SGMII IP and now it works fine
I checked the status_vector on the ILA :
status_vector (15: 0) = 0000 0000 0000 0111
@cassandra
No MDIO and MDC signals here? if not, it is impossible to move normally.
Are you talking about the following pins?
AK33: PHY_MDIO
AL31 : PHY_INT
AL33: PHY_MDC
I didn't connect to them to any port because i configured the SGMII IP without the MDIO configuration option.
Do i have to tie these pins to '0'?
@cassandra
yes ,it's these pins.
I haven't used this approach, so I don't know if you need to set it up.
but in my experience, it's not easy to use this IP, especially the first time.
Does anyone know to what value should i ties these pins to, knowing that i didn't use the MDIO configuration option in the SGMII IP that i instantiated?
Visitor 1315chw
Hello,cassandra.I'm William.I'm using the SGMII IP core to connect my PC and the K7 board.And I really don't know the function of MDIO and auto-negotiantion option.Even after I read the UG047 twice.So can you tell me their function and how should I set these pins?By the way,I also don't know how to set the pins such as status_vector,configuration vector,speed_is_10_100. Now I need to instantiate two SGMII IP core. I really don't know what to do, so can you give an idea please?Thank you very much!
 Regards,William.
