Visitor ld01422
question about bullseye
hello, I want to know about bullseye connection for vcu108 EV board
Is it possible chip to chip connection between vcu108 and vcu108 or other FPGA board which has bullseye connection?
is there any tutorial or example code for that?
I want to send and receive AXI4 interface between vcu108 and vcu108 board.
add, where can I buy bullseye cable for vcu108 ?. it is hard to find the shop and our offline xilinx support has no idea of that.
thank you.
Re: question about bullseye
The bullseye cables generally only connect the Gigabit transceivers.  You could use a protocol such as aurora to have the boards communicate through the GTs but you won't have normal IO.  Look at the aurora product guide for more information PG046.  The IP catalog will have aurora IP and example designs and aurora can connect to AXI.
