bruceyao
"axififo-connected" missed in1588 timestamp enable in Zynq UltraScale+ MPSoC
After we do 1588 timestamp in Vivado, then we export XDC file from Vivado, and then we compile in Petalinux, the device node "axififo-connected"  in pl.dtsi is losted. Related graphics and code are as follows,
Best regards!
Tags (3)
nanz
Hi @bruceyao ,
Have you compared your design with the one from our lounge?
https://www.xilinx.com/member/25ge.html
Please check the above design first and see if you could root cause the issue.
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
