TaekyungHeo
rx_enable and rx_mac_aclk of TEMAC are kept low (KC705)
rx_enable and rx_mac_aclk of Tri-mode Ethernet MAC(TEMAC) are kept low, and I cannot receive data from the module.
This is the block design diagram.
 This is my development environment.
* OS: Ubuntu 18.04.4 LTS
* Kernel Version: 5.5.0
* Vivado Version: 2020.1
* FPGA Device: KC705
The board jumpers are set properly to operate in GMII mode.
I have verified the board settings with the KC705 echo example of verilog-ethernet.
The project directory and bitstreams are attached below.
* fpga.bit: echo server example of verilog-ethernet to verify the board jumpers are properly set (nc -u 192.168.1.128 1234)
* temac.tgz: project directory
* design_1_wrapper.tgz: bitstream file and debug probes file
Tags (4)
TaekyungHeo
Additionally, I found that gmii_rx_clk is kept low also.
Does anyone have a solution to this problem?
guozhenp
gmii_rx_clk (s_axi_aclk) comes from clk_wiz/clk_out2
So is clk_wiz locked first?
TaekyungHeo
Yes, clk_wiz_locked is set to 1.
TaekyungHeo
Is this problem related to "the core bring up sequence"?
While reading the manual for "UltraScale+ Devices Integrated 100G Ethernet Subsystem v2.4", I found something like below.
It describes the core bring up sequence.
Do I need a sequence of operations to bring up TEMAC?
I tried to find a similar one from TEMAC, but I couldn't find one.
guozhenp
I don't think you need it for TEMAC.
Can you see the clock now? Please make sure all the resets released and all the clocks ready first.
TaekyungHeo
Although all reset signals to TEMAC are released, rx_reset (output) of TEMAC is kept high.
Do you have any clue?
TaekyungHeo
@guozhenp  I couldn't find a solution yet.
The key problem is that rx_reset is asserted.
I don't see this problem when I run a simulation.
Do you have any suggestions?
TaekyungHeo
I have attached a block diagram that I have used for simulation and project directory.
guozhenp
I've a quick check on your design. The simulation seems working while the clockin frequency in TestBench should be 200MHz instead of 100MHz.
Then can you add all TEMAC input/output signals into ILA for debugging? Please comparing these signals against those in simulation. Is there any difference?
